Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Vragen Bekijk alle
sim not supported for verizon on verizon network
I have installed an iPhone 6 Plus Logic Board / Verizon / 64 GB to replace my iphone 6 plus logic board verizon. When I installed my Verizon Sim Card, I get the message Sim not supported:
the sim card that you currently have installed in this iphone is from a carrier that is not supported under the activiation policy that is currently assigned by the activation server.
If the Iphone 6 plus logic board is not verizon how to I identify what carrier it is?
i have checked the IMEI number, it is compatible with verizon.
Is dit een goede vraag?
1 Opmerking
If it was me I would get a GSX report for your phone they are only a couple of dollars. If not I would find the country of sale through 3Utools and then input the imei number into all those carrier databases. The only phone I have encountered that message on turned out to be carrier locked which is shared on most networks. Good luck.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Apparently, the new logic board you installed wasn’t a Verizon board. You need to contact the seller as they apparently shipped you the wrong board.
Was dit antwoord nuttig?
Score 1
The logic board is locked to AT&T. So i must unlocked the phone using the At&T site, or go to an illegal site and pay 50-100 dollar to AT&T unlocked
Voeg je antwoord toe
DAVID NGUYEN HANG, demona zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 5
Altijd: 2,086
