Ga door naar hoofdinhoud
The 2004-2008 F-150 truck was introduced in January 2003 for the 2004 model year as the redesigned eleventh generation of the F-150 lineup.
56 Vragen Bekijk alle
My speedometer is not working properly on my 04 f150.
At a stop it reads at 60mph, while driving at about 50mph it reads at around 100-120 mph. It was working fine and then it just started doing this. I left it overnight and this morning the needle is still stuck at 60 while parked. Anyone know what is going on?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
First, try unplugging the negative battery cable and reset your trucks adaptive memory. Here is a how to article: https://www.ford-trucks.com/how-tos/a/fo...
If resetting the adaptive memory doesn’t work, check the functionality of the odometer. If the odometer is racking up miles during a dead stop, I suspect it would be your speed sensor. This is located on the side of the transmission.
If the odometer is working correctly (i.e. not racking up miles while the truck is stopped), then the problem is most likely the instrument cluster. You can replace the cluster, or try to repair it. If repairing, I’ve heard people have had success replacing a bad stepper motor, but this would require some circuit testing and soldering skills.
Was dit antwoord nuttig?
Score 3
3 opmerkingen:
This worked!
door
Resetting the memory by disconnecting the battery worked!!
door
2016 f150 - worked great!
door
Voeg je antwoord toe
Leo Rinnels zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 29
Afgelopen 30 dagen: 91
Altijd: 9,690
