Ga door naar hoofdinhoud
Repair information and guides for the iPhone 8 that was released on September 22, 2017. Model: A1863, A1905
873 Vragen Bekijk alle
I punctured the battery well it was hooked up. Will everything be ok?
Ok so I had and iPhone all hooked up ready to put back together and I punctured the battery like an idiot. I just need some help. I'm wondering will the phone be ok once I put a new battery in or is it an expensive paperweight now?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
If a punctured battery is all the damage that’s been done you shouldn’t bee too concerned, unless you’ve seen smoke or bad sparking, a new battery should be all you need.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Braxton Cary Productions zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 60
