Ga door naar hoofdinhoud
The Samsung Galaxy Tab 4 10.1 is the fourth generation of Samsung tablets that has a larger screen, higher camera resolution, and 1.5 GB of RAM.
28 Vragen Bekijk alle
Used Samsung Tab 4 Stuck in Admin mode.
My tablet is stuck on admin mode and i don’t know the password.
I can access the system recovery, but i don’t have permission to do the wipe data/factory reset.
I can update from external storage. Any place i can make a password recovery disk and put it on a SD card and boot it from there?
Any other help with this will be great full.
Thank’s Scott.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
When you mean admin mode, are you able to get past the lock screen and go through the apps list? If there is a Samsung demo / retail app installed there are guides on here on how to remove those through the apps.
When a factory reset is attempted in recovery mode a message may pop up saying MDM profile blocked factory reset.
Removing these kind of locks require either flashing via ODIN (if flashing is not blocked by MDM as well) or removing it through the installed apps.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
slingslingbinks zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 15
Altijd: 886
