Ga door naar hoofdinhoud
Also known as NX.MH1AA.011. 15.6" LED touch screen laptop released in June 2014. Intel Pentium Mobile N3520 @ 2.17 Ghz - 4GB RAM - 500 GB HDD
6 Vragen Bekijk alle
My laptop is giving me a black screen
After i accidentally hit my laptop it gave me a frozen screen. After i tried to boot it up, it gave me a black screen. After that it automatically booted up and gave me the usual Acer startup screen. It said the following ; *preparing automatic repair*
And it gave me a black screen yet again.
I have no clue what to do.
I have tried the following
-reinserting the RAM (4gb DDR 3)
-reinserting the Hard Drive (320 GB HDD)
-the 1 minute power button method
I hope this is enough for the help.
(Sorry if my English isn't good enough)
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
When you mean black Screen, is Complete black screen or there is something blinking or Logo in the startup? if you can see something in startup like a logo computer, some text or “Press something to access of boot to something” maybe is a corrupted Operating System or bad Hard Drive. A bad hard drive can cause slow booting too. If you have a live CD Linux Distribution you can try to boot up and see Hard Drive Details, If you dont have one, you can try removing the hard drive and see if you can see something on the screen.
If the computer war working really hard, and you hit it, a GPU or CPU ball soldering can happen, you can try a external monitor to check if is a component level issue.
1) Remove the hard drive and power on is you see “No Bootable Media” or goes directly to BIOS can be a Operating System or Bad Hard Drive.
2)If you have a live CD Linux Distro, and is booting up and Hard Drive Details are OK, probably is a Corrupted OS.
3)If you have more than 1 RAM Memories you can try only one, may is a bad RAM causing black Screen.
4)last and worse case, soldered ball in CPU or GPU.
Was dit antwoord nuttig?
Voeg je antwoord toe
Kirito kirigaya zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 373
