Ga door naar hoofdinhoud
Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
328 Vragen Bekijk alle
Data recovery and data transfer
Back in 2017 I installed an OWC Aura 6G SSD 480GB in my MacBook Air mid 2011.
Things were fine until last week when computer froze and is now locked so when I turn on, sign in, I get to desktop but cursor and trackpad do not work.
I may have way too much stuff on desktop. Now I contacted OWC to ask if they had an enclosure where I could put in their SSD and use it as an external drive at least to allow me to transfer data but they said they do not have that.
So I was wondering if there is any kind of adapter cable I could use that has USB capability that might allow me to connect the SSD (once removed from computer) and transfer data? Thanks for helping out.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Sounds like all you need is a new trackpad MacBook Air 13" (Mid 2011) Trackpad and here’s how to install it MacBook Air 13" Mid 2011 Trackpad Replacement
To double check plug in a USB mouse if that works then you should be able to save your system. In anywise you should then be able to backup your stuff to an external drive.
MacBook Air 13" (Mid 2011) Trackpad Afbeelding
Product
$89.99
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Lore zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 46
