Ga door naar hoofdinhoud
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586 Vragen Bekijk alle
Only starts if I first disconnect battery for a few seconds
I have a mid 2011 MacBook Pro which shows green light on mag, but will only boot if I disconnect the battery for a few seconds. I tried 2 different batteries, both show over 95% design capacity. The laptop boots with just mag power after a few seconds without battery. I have continuously unplug the battery to get it to start. However, restart seems to work OK. Baffling...yes it is the dreaded 820-2915 but this is not kernel panicking…yet. Actually was able to run “Heaven “on it, so GPU seems fine for now.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Ever spilled anything on the keyboard, sounds shorted out to me.
Let’s take a better look at it. Please run Coconut Battery and post your results.
https://www.coconut-flavour.com/coconutb...
Was dit antwoord nuttig?
Score 4
1 Opmerking:
Hey Mayer, as usual, you rock. I did put the logic board into another A1286 case, therefore another keyboard, and the issue is resolved. Humble bow into your general direction,
door
Voeg je antwoord toe
Jurgen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 61
