Ga door naar hoofdinhoud
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
iPhone SE multiple issues
Hi,
After going to a store to get my iPhone SE screen replaced my iphone does not boot up (stuck in boot loop) and cannot even hold a charge meaning it will not even power on if not connected to with the power cable.
I have tried:
  • getting a new screen replacement but the problem persists;
  • disconnecting the battery and with the cable connected (does the same)
  • resetting through itunes, it will reset and update but will still be stuck in the boot loop
Is dit een goede vraag?
1 Opmerking
Why didn't you get back to the shop that made the repair to start with ?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hmmm…erratic battery readings…?
Do a thorough visual inspection, preferably with magnification, of the area surrounding the battery connector. There are several tiny SMD components just above the connector. Of particular importance is FL2400, highlighted in red. If it is missing (which can happen when you pry the connector off), then the battery state does not get communicated to the CPU and this can also cause charging issues and fluctuating readings.
This is a common error by DIY fixers and inexperienced techs (or even experienced techs not fully concentrated ;>).
Was dit antwoord nuttig?
Score 4
Install a known good battery. The phone is boot looping because it is not getting any data from the battery.
Score 2
3 opmerkingen:
Will try that, thank you
door
Ok so I replaced the battery and managed to get out of the restart loop. However there still seems to be a problem, I left the phone charging for a few hours and it only charged 15% and it keeps restarting from X to X minutes and everything is boots up it has 1% battery and it changes back to like 8% or whatever after a few seconds. What should I do?
door
Okay so you know it is not the battery. Since it is displaying random battery percentage it would point to the tigras chip, a partial short on vcc_main or the fpc battery connector. It sounds like a microsoldering outcome in any event.
door
Voeg je antwoord toe
kraki zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 8
Altijd: 286
