Ga door naar hoofdinhoud
The Asus Zen AiO Pro Z240IC is an all-in-one desktop computer known for its 4K, ultra high definition screen and one terabyte Hard Drive. With plenty of processing power and memory, the device received the PCMag Editors’ Choice award in 2015.
22 Vragen Bekijk alle
Display not working after Motherboard Installation
I purchased a replacement motherboard (v 1.4) and have installed this according to the procedure shown in this guide. The motherboard powers on, the fan spins as it should but there is no display showing. I have tried reinstalling the RAM and re-booting but no luck . The display still does not show.
Does you have any suggestions? I am at a loss at the moment.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Its turned out to be a faulty motherboard. I bought a replacement from Alliexpress and it has worked perfectly. Got into the Bios 1st time round without an issue. We think that the graphics card on the old motherboard was the problem.
Thanks for all the help.
Was dit antwoord nuttig?
Het nuttigste antwoord
If you haven’t done so already, look through the ifixit guide again and recheck all your ribbon cable connections.
Does your model have the HDMI port? If so try connecting to another monitor or TV to see if you get anything.
Score 1
2 opmerkingen:
I have checked all the ribbon connection cables. I have even tried connecting to another monitor. It is probably something simple but at the moment I can’t work it out.
door
So you see nothing on the screen, not even able to get into BIOS?
door
Voeg je antwoord toe
Manjinder zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 11
Altijd: 384
