Ga door naar hoofdinhoud
This affordable large-screen Android phone sports a 5.7-inch display and large 3,400 mAh battery.
218 Vragen Bekijk alle
Screen messed up after isopropyl alcohol. Fixable?
So after I cleaned the board with isopropyl alcohol after some water damage but I cleaned some metal parts off the screen because there was some corrosion. After I did that the phone now starts up but the screen now looks like this now. Is this fixable or is it permanently going to be like this?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
You have moisture in between the diffuser layers of the backlight. You're probably looking at a screen replacement or at least if you have the tools and skills a backlight replacement. It looks like a replacement screen assembly is only about $30 with the frame so that probably your best option as long as your confident the phone will work still after the water damage repair.
Was dit antwoord nuttig?
Voeg je antwoord toe
jimmysofat6864 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 12
Altijd: 194
