Ga door naar hoofdinhoud
Fourth generation of iPad, released November 2, 2012, available in 16, 32, or 64 GB models. Model Number A1458
New Digitizer not responding to input
Have an IPAD 4 WIFI that had a cracked screen. Ordered a new one and replaced it with no issues during installation. Reassembled it but the screen is barely responsive and doesn’t work at all in most places.
The old screen was still working just cracked.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Probably the digitizer cable being pinched between the housing of the iPad and the screen. It needs to be folded in a way that it doesn't get squished when the glass is installed.
Always remember to test digitizer before install. You'll need to replace the digitizer again unfortunately.
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
The cable isn't squished. There's no sign of damage to it either.
I tested the digitizer as best I could.
door
In this case it's going to either be the digitizer going bad or the connector for digitizer needs cleaning.
Dust can get inside the connector so may need to be cleaned carefully with a soft brush and isopropyl alcohol.
door
I'd hope the digitizer didn't go bad its brand new.
I'll try to clean it out now
door
Voeg je antwoord toe
Tyler Evangelista zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 17
Altijd: 102
