Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
1041 Vragen Bekijk alle
Why is my phone not turning on
So my phone was working perfect until my charger broke and it it completely died I got a new charger and it showed it was charging for a few second then my screen went black and I can’t even hard reset or connnect to apple iTunes so I got the battery replaced it turned right on with the new battery but it wouldn’t charge the guy said I needed a new charging port so a month later I went back and got the charging port fixed too now it still won’t do anything and I had it plugged in over night with an apple charger please help my phone is barely over a year old
Is dit een goede vraag?
1 Opmerking
Google ‘iPhone Tristar issues’. That’ll give you some answers :)
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
It sounds like the charing circuit may have been damaged because the phone works when you have a fully charged battery installed. Was the charger you owned or replaced it with an Apple original? Low quality chargers can damage the charge circuit.
You could try a new charge port but IMO you have a logic board issue. This can be repaired but you will need to find a shop that does micro-soldering repairs.
Was dit antwoord nuttig?
Score 4
Voeg je antwoord toe
Hunter zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 53
