Ga door naar hoofdinhoud
Flagship smartphone from Huawei released April 2018. Model CLT-L29.
56 Vragen Bekijk alle
Where is the GPS chip/antenna located
Hi Guys,
Need your expert here. My GPS suddenly doesnt seem to be working. I have tested using Hi Care app and it says that the GPS module is working. I have a hunch that there connection (antennas) might be loose. Can you guys point out where can i zoom into so that i can repair it easily? I think there is no proper contact between the antennas and the GPS module.
Thanks guys in advance. Appreciate your help.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
This smartphone has a built in GPS receiver, which is in the mainboard, which is everything in line with the cameras/flash and higher.
You can check out the entire teardown from iFixit by Tobias Isakeit here below!
Demontage van de Huawei P20 Pro
Was dit antwoord nuttig?
2 opmerkingen:
Hello Albert is it possible to mark the GPS Chip for me? Thank you
door
@ahmet kara Hi Ahmet, my pleasure. Just check out the image, thank you~!
https://imgur.com/oPc7BvH
door
Voeg je antwoord toe
Kalpesh Shah zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 29
Altijd: 3,334
