Ga door naar hoofdinhoud
PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
Problems with my 2 controllers
So I’ve had both of my controllers since the release of the ps4 back in 2013. The controller i use most has a problem where i would plug it in to the ps4 to charge, then it would look up for no reason without moving the right stick. My second controller i use less, has problems where running feels sluggish, sometimes closes out of menus, and sometimes shoots my gun without me pressing R2. How can i fix these problems?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Seems that dirt /dust has accumulated inside the Controllers. Cleaning the interiors of the Controllers should solve the problem.
Was dit antwoord nuttig?
Score 1
One option would be to try resetting the controller. Under the L2 button there is a small hole on the back of your controller. Using an unbent paper clip, hold the button down for about 3-5 seconds. This will reset the controller. Now plug your controller into your PS4 and re-sync it for a successful reset. If this doesn’t work, then definitely try cleaning it out to see if that resolves the issue.
Voeg je antwoord toe
Lance Beltrano zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 104
