Ga door naar hoofdinhoud
Reparatiehandleidingen, demontage- en probleemoplossingsinformatie voor de 6e-generatie Apple iPad, verkrijgbaar in Wi-Fi- en cellular-modellen met 32 of 128 GB aan opslag. Gelanceerd in maart 2018. Te identificeren aan de modelnummers A1893 en A1954. Bevat een 9.7" Retina-scherm en 64-bit A10 Fusion-chip.
Home Button doesn't work after iPad 6 screen replacement
I have been repairing electronics for years. Never had any issues with iPads until recently, home buttons stop working after digitizer replacement. There is no damage to the home button or the cable or anywhere. Anyone else having this problem?
Or have found a solution?
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
2 Antwoorden
It could just be an alignment issue, is the metal part of the home button bracket (which is the contact for the button) aligned with the center receiver of the home button?
Was dit antwoord nuttig?
2 opmerkingen:
No, it even makes the clicking sound and everything. Even when I install a new button, still doesn't work.
door
The clicking sound is not an indicator of anything. Try to align it better with the bracket. I had this issue as well last week.
door
Look at the back of the home button. There should be a tiny black dot in the center of the switch. If all you see is amber that dot has fallen of and the switch will not work when installed.
Voeg je antwoord toe
minnabeezy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 1,300
