Ga door naar hoofdinhoud
De Nintendo Switch is een draagbare spelconsole die via een dockingstation op de tv of onderweg kan worden gespeeld. Uitgebracht op 3 maart 2017.
706 Vragen Bekijk alle
What is this charging-related component?
I got a Switch in that isn't charging. It was assumed it was a charging port issue, but upon closer examination, I saw this:
It clearly has an “S”-shaped hole in the top — it's fried. That component connects the upper copper plane to the fourth pin on either side of the charging port (of the row that's exposed in the back) (VBUS?).
The upper copper plane leads to the charging IC, second pin on the bottom right:
So, likely the charging chip must be replaced, however even after replacing it, I'm still left with that component with a hole burned in it. Can anybody identify the component? I'm guessing it's a fuse or ferrite bead, but it might even be a resistor. In any case other than a resistor, I could just jump the pads with a wire and probably be fine. But, if it is a resistor, knowing the value would be very helpful.
Chuck R
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Hi Chuck,
The component in question is a 0.02 Ohm resistor. The board I used to confirm this has a slightly different configuration but the pathways go to the same places.
Hope this helps!
Happy fixing :-)
Was dit antwoord nuttig?
Voeg je antwoord toe
Charles Ricketts zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 133
