Ga door naar hoofdinhoud
The first Android smartphone from Google, the Pixel XL (Model Number: G-2PW2100) was launched October 20, 2016. It has a 5.5-inch AMOLED display, 3450 mAh battery, and 32 or 128 GB storage options.
67 Vragen Bekijk alle
Crackling noises after loudspeaker replacement.
Hello again. I swapped out my loudspeaker, and all I’m getting is crackling / electrical noises. I checked the spring contacts touching the loudspeaker and they are not the problem.
I’m assuming that either
a) The replacement speaker is defective or
b) Something else is causing the audio issue.
Any idea what other components (aside from the motherboard) I can try swapping out to fix the audio issue? The daughterboard doesn’t seem to have any sound-related ICs on it. Thanks
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
My guess that its a bad loud speaker, it always depends where you could have gotten the part from, We take a chance with buying these 3rd party parts because sometimes they’re not fully tested before listed on the market.
Was dit antwoord nuttig?
1 Opmerking:
I just ordered a second replacement loudspeaker (third loudspeaker overall). Not confident it will resolve the issue, but I’ll keep you updated nonetheless. Thanks
door
Voeg je antwoord toe
Zeev zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 43
