Ga door naar hoofdinhoud
Guides for the Wi-Fi version of the iPad Mini 4—model A1538. Announced on September 9, 2015, the iPad Mini 4 is the successor to the iPad Mini 3.
97 Vragen Bekijk alle
iPad Mini 4 - Screen/Digitizer not seating correctly.
Hey all, New to the forums and new to working on a iPad Mini 4 reassembly. We had to replace a digitizer that was cracked with a brand new one, my only issue with it is trying to close the whole thing back up. Currently the issue persists near the bottom right hand corner of the screen but it can be the top right hand corner as well (Its usually on the right hand side.) My Theory is that the cables that attach from the digitizer and the board are not wanting to seat correctly and keeping the screen popped up. Attached with this post is a image of said iPad Mini 4, any help would be appreciated.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Your theory is on point - cable is not folding in the right direction causing screen not to sit flush, you may also want to remove old adhesive and use Tesa 61395 tape, this is currently the best adhesive for screen repair.
Tesa 61395 Tape
@refectio wrote a great guideline for iPad screen repair, check out his answer in this post:
After doing my repairs (battery and screen) I have problems
Tesa 61395 Tape Afbeelding
Product
Tesa 61395 Tape
$5.99
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
For the Digitizer cabel itself, besides making sure its folded right, is there any other way to secure it say with kapton tape or double sided tape to make sure it just stays in place?
door
@militiatech I don't believe taping is necessary if cable is properly folded and seated (it's a flex cable after all). That said, secure it with kapton tape or double sided adhesive won't do any harm and will hep securing it to some extent.
door
Voeg je antwoord toe
Jacob zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 225
