Ga door naar hoofdinhoud
Repair information for the game cartridge used for Gameboy Advance games, also known as the AGB-002.
Can you replace save chip in Pokemon leafgrean cartridge
My Pokemon Leafgreen cart save chip is dead and if I could replace it or not and if possible it's cheaper than buying a new cart
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Not likely unless you know micro soldering. The innards are all soldered into the gameboy cartridge board. The memory chip is the black box on the right of the chip. Its also unlikely that you would find a chip replacement unless you can desolder it from another identical cartridge then solder that into the board of that cartridge. (very difficult) Essentially the answer is no. It would just be cheaper and easier to replace it.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Bryce Stidman zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 1,135
