Ga door naar hoofdinhoud
Mac OS X 10.4 Tiger download possible?
Is there any where some one can download Mac OS X 10.4 Tiger that will work on Powerbook G4? i badly need it and i don't know where to download the correct version that will work with my G4.
Is dit een goede vraag?
Score 26
Voeg een opmerking toe
6 Antwoorden
Gekozen oplossing
Your unit came with Panther (10.3). You can get a copy of the original Grey disk from Apple for about $15. If you want Tiger you need to buy a Retail copy (Black) to do the install. Apple has not had a downloadable OS since OS-9. You could probably find a illegal copy online but most people find problems with such downloads including trojans and other malware.
Was dit antwoord nuttig?
Score 13
2 opmerkingen:
+ Ralph, are you sure Apple still sells original installation disks for older machines?
door
They did the last time I checked but that been three months or so.
door
nothing legitimate that I'm aware of.
Regarding the version, any OSX 10.4 will work on any Powerbook G4 except for the Powerbook G4 (Dual Layer SD) which requires 10.4.2. Accoding to your post stating model A1010 or A1104, you will have no problem wiht any 10.4 disc, as long as it's not a disc form another mac (the gray discs).
Score 4
2 opmerkingen:
Hi ,where can I get or download a 10.4.2 Installation disk iMac G5
door
You will need either a retail version of 10.4 or a upgrade 10.4 if you have 10.3. You can also use machine specific (gray disks) made specifically for your machine (beware of the gray disks made for other machines with the exception of the gray eMac disks which install on all the machines. FastMac carries all these disks: http://fastmac.com/osx.php
Score 4
1 Opmerking:
Got to learn to type faster. +
door
Bien hasta que lo encontre ahora espero funcione!! :D
Well until I found it now I hope it works! : D
Score 1
I have a problem in my Ibook G4 I clicked the Mac OS 10.4 and now it does not keys - esp, caps look, and the delete key please help.
Score 1
Here you can find freely macosx versions for ppc
http://macintoshgarden.org/apps/mac-osx-...
Score 1
1 Opmerking:
Hi Makomail,
Does your link works with eMac 2004?
Thanks for the answer!
door
Voeg je antwoord toe
Julius Nfor zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 24
Altijd: 84,953
