Ga door naar hoofdinhoud
The Xbox One X (Model 1787) is Microsoft's high-powered game console, succeeding the Xbox One S. The Xbox One X was released on November 7th, 2017.
20 Vragen Bekijk alle
Xbox wont turn on
When the power button is clicked, the noise beeps like it is turning on and then followed by a high pitched screech and then it will turn off shortly after. the tv shows nothing other than a trouble shoot page and occasionally nothing, I've tried, plugging and unplugging, factory resets and nothing works
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
ok so, i hate being the one to admit this… but this happened to me before, but i caused it. Does the sound (sound) like its coming from where the fan is? Like maybe a mechanical screech? If so, its the fan hitting something inside. What i had to do was remove the casing (dont do this unless youre ok with voiding your warranty) and kind of bend the metal around it back into its original position.
Was dit antwoord nuttig?
Your vents might need cleaning. You can use a Compressed Air Canister, or just a simple vacuum. That fixed close to the same issue on one of my Xbox 360s.
Voeg je antwoord toe
Benjamin Vidjen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 577
