Ga door naar hoofdinhoud
Computers die over het algemeen geen geïntegreerd scherm hebben, en die bedoeld zijn om te blijven staan.
2133 Vragen Bekijk alle
Vizio CA24 stuck on PC Off when booting.
So I recently purchased a secondhand Vizio CA24 All in One Desktop. It was missing a hard drive, WiFi card, and ram which I supplied, yesterday I had it running windows but this morning it gave me a message saying PC off in the top right of the display, I took everything out of the computer and put it back in, but it still refuses to work! Any Ideas? Thanks!
Is dit een goede vraag?
2 opmerkingen
Hi Jon,
Let me get this straight. I'm assuming you installed all the missing parts and then installed Windows and it booted up fine. Next day itwould not boot up>
Also
Specifically which model of Vizio CA24 is it?
What happens when you press the power button?
Do any lights come on?
Can you hear anything?
Can you get into the BIOS? Usually one of the following keys - F1, F2 orDel.
Did you check that all the cables are correctly connected?
When you took everything out of the computer were you careful to discharge any static?
Let us know.
door
PSU failure? Fried chip? Imcompatible RAM (Since it's an OEM PC)
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
This is a well-known problem with the Vizio CA24 computer. Since it seems to be a manufacturing defect unique to the Vizio CA24, your best bet may be to contact Visio customer support directly.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Hi, how I get actually bios update for VIZIO CA24-A2
door
But the home page of VIZIO don't have any support
door
Voeg je antwoord toe
Jon The Otaku zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 1,091
