Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Vragen Bekijk alle
Touchscreen does not work while on charge
I bought a 5s off of eBay for $20, not turning on or booting. I replaced that battery and dock connector, and it worked great. The touchscreen was fine and everything worked perfect. When I put it on charge though, the touchscreen is glitchy, touching apps will bring down the search bar and the scroll on safari is all messed up. When I take it off charge it works great tho. Any ideas?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
It seems to be the new charging port. When you charge the phone, thats when it activates the charging port the most. I would try reconnecting the charging port and battery connector and turn it on again to test the charger. If thats not the case than it must be a screen issue that was caused by the previous owner.
Was dit antwoord nuttig?
1 Opmerking:
Before going to all the work doing that, it also is worth seeing how well it works charging it using a different charging cable and/or wall adapter. Sometimes a cheaply made charger can interfere with the display's functionality. If it's not that though, it likely is something with the display, or the new charging port.
door
Voeg je antwoord toe
Andrew Coppola zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 34
