Ga door naar hoofdinhoud
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
580 Vragen Bekijk alle
Battery percentage not increasing
Greetings,
I bought this Macbook about 5 years ago. Have never replaced the battery. No physical or water damage has occurred.
When I updated to Mojave, the laptop gave me a “Service Battery” message. I checked my battery cycle count and it was around 300, so I ignored the message. The laptop worked fine for a few months without issues.
The situation today is as follows: the battery percentage no longer goes up. It is either stuck on a particular percentage when it’s connected to power, or the percentage goes down when I disconnect it from power. But the battery never actually charges. In ‘System Information’ the Mac recognizes that the AC charger is connected, but it says it is not charging the laptop.
This has happened to me a couple of days before. After restarting the Mac, it fixed itself.
Today this happened again, I tried to restart, reset the SMC, and update the OS to the latest version, but to no avail.
Online, I read recalibrating the battery might fix the issue. However, I fear that if I drain the battery to 0, the Mac won’t open again. There’s also no way for me to get it back up to 100% as it currently stands.
Does anyone have any ideas? Or must the battery be replaced (despite the low cycle count)?
Thank you in advance!
Is dit een goede vraag?
1 Opmerking
Thanks everyone. Guess I’ll have to replace it then.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Despite the low cycles count your battery is in awful conditions. It probably won’t stop charging if you let it go down to auto sleep mode, but it won’t help either. “Calibration” is a good subject to entertain forums discussions and sometimes to fine tune system percentage counts but it actually does nothing to improve a battery condition..yours clearly needs replacement. As a side note for future reference, never let a lithium battery drain for more than a few hours..sometimes a full week drained is sufficient to kill a perfect battery.
Was dit antwoord nuttig?
Score 3
Batteries can fail early, yes 326 is on the low side but it’s not that rare. You’ll need to replace it.
You should also check your MagSafe charger make sure its a real unit some fakes look the same! But can be deadly to your system OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth & Compared: Fake vs Genuine Apple Magsafe Chargers
Also make sure the cable and the connector interface are in good shape if damaged or worn replace the charger. Apple Portables: Troubleshooting MagSafe adapters
Score 2
Voeg je antwoord toe
Yedai Qum zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 15
Altijd: 5,015
