Ga door naar hoofdinhoud
2.6 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.2 GHz) with 3 MB shared L3 cache. Released February 13, 2013.
Battery capacity decreasing after swap
Hi, everyone,
so I bought a replacement battery here and i switched and everything was ok for a few hours, then, after calibrating, reseting nvram and the smc, coconut battery is giving me weird reading.
Just when I installed the battery, the design capacity was at 100% as it should be, but after only 2 cycles in, and all the calibration and reseting, coconut battery is telling me the battery’s design capacity is at 89%.
Am I doing something wrong? Am I missing something? what’s going on? again this is a fresh batty from fixit and I did calibrate it twice, that’s the 2 charge cycles the battery has right now. I can always try again but this seems weird and I don’t know if its normal and it’ll stabilize later or if this battery is defective. Ill attach some screenshots from coconut battery.
Thanks!
Is dit een goede vraag?
Score 1
1 Opmerking
Yep! You have a bad battery, contact the seller for a replacement.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I’d give it a chance and calibrate it again before going though all the work of replacing it again. Let it drain down to 10% then fully charge it again and see what reading you get.
Was dit antwoord nuttig?
Score 4
1 Opmerking:
Thanks! ill probably calibrate it again tonight and see what happens
door
Voeg je antwoord toe
Jorge zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 337
