Ga door naar hoofdinhoud
Released November 2018 as an edition to the iPad's Pro line. Model A1980.
Replace display, what glue?
Hello,
I am going to replace a display on a iPad pro 11.
The display I am buying do not have glue/tape preinstalled.
What is recommended to use on this model? Didn´t find too much on this model when googling.
  • Thanks!
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
I always use tesa tape on all tablets I repair. I do have to custom cut some bits using an exacto knife, but I get excellent hold and fit using it.
Tesa 61395 Tape
Custom cut rolls of Tesa 61395 double-sided tape for repair. Afbeelding
Product
Tesa 61395 Tape
$5.99
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
Thanks!
Should I just take the 1mm?
Do I tape all around the edges or only in certain spots?
door
Id probably go with the 1 mm. Once you take off the broken screen look at where the adhesive tape is on it and copy that.
door
I would also suggest that you place the device screen down with something heavy that can apply even pressure on the back of the device. This will help the adhesive stick better.
door
Yes ther is glue. The glue goes along the edge to hold it in place. Here is a top quality iPad Pro 11" (2018, 2020) Screen.
Replace a scratched or cracked front glass digitizer panel or a malfunctioning display. This part is compatible with an iPad Pro 11" 1st Gen (2018) or 2nd Gen (2020) tablet. Afbeelding
Product
$209.99
Voeg je antwoord toe
Joakim Egeland zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 1,300
