There are methods that can be used in order to fix your phone that is power-cycling:
1. Check your protective case
Some protective cases are a little too snug and can actually put pressure on the power key causing the phone to power off or on sporadically.
2. Make sure the battery is snug
Make sure that it’s nice and snug and that the metal leads on the phone and battery are staying connected to each other.
3. Check the batteries condition
Check the Liquid Damage Indicator (LDI) on the battery and make sure that it is still white.
4. Run a battery test
5. Check your applications
6. Upgraded Software
7. Backup and reset
Resetting a phone is often a last resort for most situations but a factory data reset on an Android phone can often times fix most phone related issues, especially when it comes to software.
Hope this info helps.
Does it fully boot into android or just get to that startup slash screen and boot loop?
door Zac Marino
Do you fix Alcatel phones
door Angus McArthur
Hi Angus,
iFixit does not repair anything; they are a site dedicated to providing information to allow people to repair their own devices. They do not provide referrals either, but if you post your physical location (i.e., country, city, whatever you're comfortable with), you may be able to solicit suggestions from users on here in your area.
Depending on what model phone you have, there are some self-repair guides available for various Alcatel phones on this site if you are interested in fixing it yourself.
door Jerry Wheeler
I don’t have a answer but I know one thing my battery is one that cannot be taking out… there very little I can do to keep the power on…. It frustrating…
door alex valles
I have an Alcatel Flip phone 4, it has had this problem, too, I was sent a text from Sprint/T Mobile, that I needed an upgrade, and I ignored that text. Then I decided to download the upgrade and install it, that went well, only took a few minutes. It seems, so far, that the upgrade may have cured the problem, my fingers are crossed....
door rick dees
