Ga door naar hoofdinhoud
Hewlett-Packard begon in 1993 met de productie van laptops.
3333 Vragen Bekijk alle
HP Envy x2 12-e0xx Ram/SSD Upgrade
Hello,
I have a Hp Envy x2 detachable 12-e0xx laptop/tablet and I was wondering if it is possible to upgrade its ram from 4gb to 8 and If it is possible to upgrade the storage on it besides using an micro sd card.
Thanks!
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi Matt,
No, unfortunately you can not upgrade the memory to 8 GB. The ram is already soldered on the board.
Attention, this model is not easy to open.
About the memory card, yes, you can use a memory card to extend your pc stockage. at this moment you can do it by the settings of windows 10. Settings >> storage >> change where new content is saved >> choose your SD CARD
Good luck
Adel
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thank you for your quick response I appreciate your time and help!
door
Assuming this is the HP Envy x2 12-e091ms this uses on board memory and flash storage so it is not possible to upgrade either the ram or storage on this device.
Score 1
1 Opmerking:
door
Voeg je antwoord toe
Matt M zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 1,249
