Ga door naar hoofdinhoud
The eMac was an all-in-one G4-based Mac designed for the education market and released in April 2002. It was the last Mac to use a CRT display and was sold at a low price to schools and other institutions.
47 Vragen Bekijk alle
No Sound Coming From Speakers
A few days ago. I played music too loud (at the max volume). It was working fine. But now, the eMac chimes but the internal speakers don’t show up in control panel. (I am running Mac OS 9.2.2, and yes it is a 700Mhz eMac, so it is compatible!) I only have Mac OS 9 installed at the moment.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
There is very little which you can fix on this system. As the sound preferences are not showing up I would try resetting the PRAM Reset NVRAM or PRAM on your Mac and given the systems age you may need to replace the PRAM battery eMac PRAM Battery Replacement
If that doesn’t work you damaged the DAC logic on your logic board. Which would need a new logic board.
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
I have a spare battery that I think would work with the system I am going to try and replace the PRAM battery.
door
This is a 1/2 AA 3.6 volt lithium ion battery.
door
Yes that is the battery I have I think
door
Voeg je antwoord toe
Owen Ready zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 140
