Ga door naar hoofdinhoud
The DOSS SoundBox can be identified by its model number: DOSS SoundBox on the base between the feet of the speaker. Its a fourth generation bluetooth wireless audio player that was released in 2016.
24 Vragen Bekijk alle
Why is my speaker repeating a single sound of a busy phone line?
My speaker has suddenly began making a single sound every few seconds which sounds like a single busy signal on a phone. I have read the manual, turned off/on both speaker and phone without success.
Is dit een goede vraag?
Score 12
29 opmerkingen
I'm having the same problem...
door
I am also having this problem
door
Same here. Anyone have an answer yet? I'd be sorry to let this speaker go but, it's really annoying.
door
I’m also looking for a fix of this problem.
door
Same problem here. I thought it was cuz I have a cheap speaker but if so many people are having the same issue...
door
24 commentaren meer tonen
Voeg een opmerking toe
11 Antwoorden
Gekozen oplossing
It's low on battery. Plug it in!
Was dit antwoord nuttig?
Score 12
6 opmerkingen:
Yes, I figured it out early on. But you were right and it was very nice of you to take the time to answer.
door
Mine is plugged in and I have a busy signal constantly
door
My Journey exhibits the same problem. I wouldnt have thought 46% would be considered low. Why doesnt it just nag me to turn on battery saver?
door
cjwidomski It may be pugged into a "low" power usb port. Change to a more direct charging port. (This happened to me when I plugged it into a "monitor usb" port rather than a direct power port.)
door
The exact same thing was happening to me and like the others it just needed to be plugged in. I plugged it in and just kept using it until it was full
door
1 commentaar meer tonen
Mine just needed to be charged. I think the busy signal tells you it needs a charge. We all get hungry!
Score 5
1 Opmerking:
Luv your comment
door
The best answer I have for you is that your rechargeable battery needs to be replaced inside the unit. It probably is charging at a very low rate and even though it still powers the unit, it needs to be changed out.
Score 4
2 opmerkingen:
So where is the compartment to replace battery
door
you have to open it up. Carefully remove the front grill and you'll see the screws.
door
There may be a warranty on it. You can contact the seller directly about warranty information on Amazon.
2 opmerkingen:
There is no one to call
door
I have the same issue, a High Serria speaker that I got at a convention. Plugging it into a good wall USB charger, it shows three solid lights and one flashing when charging, so it is showing me it has a charge. The two "busy" beep sounds will not stop if it is charging or not. Not until I turn the unit off does the busy signals stop.
door
I replaced the lithium batteries myself by soldering new ones in place of the old and it’s working properly now. Batteries are 3.7 volt rechargables. Can get online or at specialty stores.
2 opmerkingen:
The sound of a busy signal on my new speaker meant it needed charging. I charged it and the busy signal stopped.
door
Mines doing the same but its coming out of the phones call speaker and I have nothing open
door
Mine ended up after I replace the batteries being the battery charger built-in to the circuitboard so now I swap the batteries from the one functioning speaker to the other it’s a bit of a pain but it works
Charge the battery in your speaker. The busy sound means it too low in power.
Update (09/19/2020)
You need to charge up the battery. The signal is telling you it is too low.
1 Opmerking:
I thought it was supposed to be solar powered, so why isn’t it keeping charged?
door
After plugging the speaker If the charge light does not come on the internal charge circuit Has failed. I realized this after replacing the batteries which are soldered in and cost 25.00.
1 Opmerking:
I see that almost everyone is saying the phone is low on battery and needs to be charged. However, my phone does it when it's fully charged.
door
It’s telling you that your battery is going to run out soon.
Mine beeps at 20% power or less, interrupting my movie or music every few seconds. I have a “Curve” brand of earphones that I bought in a retail store.
There should be a setting to cancel that sound and simply enjoy listening to the movie or song until the battery runs out. But there is no setting.
I would advise against buying this speaker.
Same problem. Someone above mentioned that they “replaced the battery”?? . . . But mine charges via USB. ???
2 opmerkingen:
My LG Stylo was doing the same but one I activated Device Pulse it has stopped. I knew it was not the battery because my phone charges just fine & keeps a good chargeall day.
door
My issue is that when my Bluetooth speaker is connected to my phone and i receive a phone call it keeps on repeating the same phone number everytime after the call what to do please
door
Voeg je antwoord toe
Judith zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 24
Afgelopen 7 dagen: 209
Afgelopen 30 dagen: 1,042
Altijd: 50,428
