Ga door naar hoofdinhoud
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Vragen Bekijk alle
iPhone SE black screen
i have an iphone SE that is fallen while its charging and the screen goes black, i have tried to reset, change the display and change the battery but the problem still exists, itunes detects the iphone when is connected to the pc and i have already done the reset also with itunes, someone can have an idea of where the problem can be ? thanks
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
These iPhone SE’s tend to have a lot of problems. It because it came out after the iPhone 6 and 6s. They put a bigger processor than the iPhone 6 inside of the SE. The next step I would do is try reconnecting the battery connector and the screen connectors. If that doesn’t work I would take it in to a local 3rd party repair store. PLEASE DONT TAKE IT TO APPLE! The 3rd party repair store should be able to do a diagnostic on the phone. Hope nothings wrong with the phone. Best of luck!!!
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
thank you for the answer, i have tried to reconnect the connectors but the screen is still black, maybe there is a short on the logic board that i should not be able to find, i think i will contact a repair store, thank you again.
door
@Simone Any update on this?
door
Reset the phone (no data loss): press both the home and power buttons for up to 1 minute, releasing when the Apple logo appears.
Voeg je antwoord toe
Simone zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 680
