Ga door naar hoofdinhoud
Leer bij over vaardigheden die je nodig kunt hebben om aan jouw toestellen te werken.
77 Vragen Bekijk alle
Non-ESD mat, used with a ESD mat.
I recently bought a silicone soldering mat that has notches and grooves and it really helps with organizing my work space during projects (mostly phone repairs) . But I did some research on the mat and found out it was not ESD safe. So, my questions is that if I did buy a ESD safe mat, would it be okay to use the non-ESD safe mat on top of it.
In other words, ESD safe mat on the bottom, and silicone non-ESD on top. Would there be any static electricity generated.
Thanks, for the help. New.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Sadly you still run a risk even when you have an antistatic mat under it.
As an example if you take a ballon and rub it on some cloth so it builds a static charge. The charge is strongest at the location where you rubbed.
Why don’t you use some anti-static spray on it before you use it to be safe.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Juan Lopez zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 10
Altijd: 205
