Ga door naar hoofdinhoud
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1364 Vragen Bekijk alle
Why is my touch screen not working
I bought a iPhone 7 Plus and I bought it as faulty as the screen was not working, so when I received it I got the screen replaced it started working fully then I repaired it I replaced the back housing which involves switching the motherboard after the repair when installing the screen back on there was a bit of adhesive on the the gold circles on the motherboard next to where the screen goes so I scratched the adhesive off with a screwdriver after that I installed the screen and the touch stopped working the phone turns but the touch does not work is there anyway I can fix this?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
“Scratching”, “Screwdriver” and “Logic Board” are not three words that go well together when it comes to iPhones :>).
I can’t really say I fully understand what you are referring to so perhaps you could add a picture to your post so that I can get a visual. However, I will say that based on your description, my fear is that you may have damaged the logic board. It could be a damaged connector or the tiny parts that surround the connectors. If you have a jewelers loupe or microscope (or just great young eyes!), take a closer look at the area you played around in to see if there is any signs of damage.
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
Since the touch isnt wokring can it be the touch ic that needs replacing
door
The Touch IC is embedded in the screen, not on the logic board.
door
What do you think the problem is and can it be fixed?
door
It could have internal damage. Apple also likes to screw with you because they don’t like people fixing there stuff for a reasonable price. So Apple will at times make things stop working or malfunction. Maybe check everything is where it should be and maybe try again. Or maybe get a new screen and try again. Hope that helps.
2 opmerkingen:
I’ve tried 2 new screens both of them not working the touch is not working
door
I don't really know then. I'm really sorry, hope it all works out. Have a good day
door
Was the adhesive u scraped just the black slimy stuff around the housing edges??
I think the first place to start would be to try a new screen, remember to carefully remove the original home button flex
As minho said touch screen controller is on the screen itself, u could have done some other damage to the board as well but cheapest easiest and most logical course would be to try another screen first :)
Obviously first check the connector for the screen is fully plugged in sometimes the longer connector which is for the actual screen itself doesn't plug fully/ in so check thats firmly in first before trying a new screen
2 opmerkingen:
Hi I’ve tried new screens and still the touch is not working the adhesive was on the motherboard it was a little piece of black adhesive in between the connector, I don’t know what’s the problem I think it’s a motherboard problem
door
The adhesive u peeled off like a foam cushion around the connector, as uve peeled that uve probably knocked off a cap, resistor, filter or other ic off the board... really the best way forward is to check it properly under a microscope, try not to do anymore without having a look carefully under a scope as the ic and its pads might still be there poking it etc will just make it more awkward to repair
door
Voeg je antwoord toe
Phones repair zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 129
