Ga door naar hoofdinhoud
Repair information on hard drives or hard disks. Hard drives are magnetic data storage devices. They are used in most desktop, laptop, and server due to their low cost and high data density.
143 Vragen Bekijk alle
Why can't I install osx into my drive?
So I'm using a mid 2009 15" MacBook pro and recently purchased a 500 GB Hybrid Seagate SATA Hard Drive, followed all the instructions, ie, disk utility format, format. But it always gets stuck in the middle of the installation process for example it says 24 mins left and 2 hours later it's still there. Eventually an error message would pop up saying installation error please restart or disk error please try on another disk. I've had the hard drive replaced and the same error pops up, I've tried a different osx installation disk and the same error popsup, what am I doing wrong?
Is dit een goede vraag?
Score 1
6 opmerkingen
Is it this drive? [gekoppeld product ontbreekt of is uitgeschakeld: IF107-098]
Where did you get it from?
door
Yes, that's the one, I got it here, ifixit.
door
Are you using the software that came with the computer or at least a retail copy (black) of the software. If you are using a grey disk for another computer you sometimes have this problem.
door
If you have access to another Mac and an external SATA hookup use a program like "super duper" to make a bootable clone, then repair permissions,
door
I even tried the snow leopard copy I got from apple store and it doesn't work, i'll try the external way when I get the enclosure.
door
1 commentaar meer tonen
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Try reformatting the drive using Disk Utilities and the "write zeros" option. This will map out any bad blocks that might be causing your installation to stop. Then try installing the system.
Was dit antwoord nuttig?
Score 4
7 opmerkingen:
Trying this method out as of now.
door
Okay, there is a problem, it says disk erase failed, " operation could not be completed. Cannot allocate memory" so I'm assuming it's my ram now? I've got 4 gb of ram though. Please advise further.
door
I'm doing more research now, but first thing is we've seen this before and it was a bad drive, will get back soon: Cannot format new HDD under 10.6?
* Read this and give it a try: http://reviews.cnet.com/8301-13727_7-104...
door
Thanks Mayer, but I would like to add that I'm doing this on a replacement hd ifixit sent to me, meaning this is the 2nd brand new hard drive, I would doubt it's the drive fault. But I'm really lost at this point after reading the links you sent me. I'll try out the command method. Thanks.
door
Was the old hard drive working properly before you started this?
door
2 commentaren meer tonen
Here is a link to Apples guide for installing Snow Leopard. Hope it solves your problem.
http://support.apple.com/kb/HT3910?viewl...
Score 1
1 Opmerking:
Yes, I know how to reformat a computer. But the case is, I just bought a new Hard drive, and it shouldn't give me any problems reformatting. But it did, it gets stuck half way through each time, I don't know if it's the hard drives fault or my computers fault.
door
Gave up trying, Going for another HD. Thanks Ya'll
Voeg je antwoord toe
minyonglam zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 13
Altijd: 3,423
