Ga door naar hoofdinhoud
Guides for the LTE version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, originally known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
62 Vragen Bekijk alle
How do I turn off my iPad when I accidentally took out my front panel
So I was following a guide in Front Panel replacement and I didn’t turn off my iPad before taking the front panel out.. Now I am in the process of taking out the LCD, how do I turn my iPad off?
iPad Mini 2 LTE
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Unplug the battery first then unplug the other cables. Unplugging the battery is the same as turning off the iPad.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
To add to this, the battery connector is right next to the LCD connector as shown starting at Step 40 in the LCD replacement guide: iPad Mini 2 LTE LCD Replacement
Disconnect both and you’ll be good to go!
door
Voeg je antwoord toe
Synergy Plays zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 6
Altijd: 44
