2005 Toyota Tundra. Headlights are not working
Started by replacing bulbs often, then both Low beam lights would not work. The only one working is the High beam on passenger side. Changed out dimmer switch. Did not resolve issue.
Is dit een goede vraag?
Score
0
Hi @southernlady74 ,
Have you checked all the fuses for all the headlights and also checked if there is voltage at the bulb sockets when the lights are turned on, you didn't say what else you had tried?
If there is voltage present at the bulb(s)' connector with the lights switched on, check if the earth connection is OK
door jayeff
Fuse(s) blown? No power? Damaged ground?
Check these, and comment if issue still persists.
Good luck!
door Jessica Parnelli Fawkes
