Ga door naar hoofdinhoud
6th generation of Motorola's Moto G line. This phone was released in 2018 and features a glass back that is easier to remove than Samsung phones. Model numbers are XT1925-4, XT1925-5, XT1925-6, XT1925-12 and XT1925DL.
36 Vragen Bekijk alle
How to replace the battery in a Moto G6
Most info I have seen from Motorola says this must be done by a factory certified technician, or you void the warranty.
The battery photo shows a connector on leads, so it would appear to be a simple task once the back is removed.
What is the step by step process to replace the battery?
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
You can use the screen replacement guide to walk you though the steps.
A few cautions. If your phone is under warranty then this will most defiantly void the warranty. I would look into what options you have to get the battery replaced under warranty. How long have you had the device?
When taking the back off, it’s really easy to break the back glass. Use a lot of heat and take your time. A thin pick will help and be careful around the edges. Make sure the back stays hot. This will help keep the adhesive loose.
Keep track of your screws and make sure you know what goes where. Use a little heat and a pry tool to loosen the battery. Just be careful about puncturing the battery. If you can get under the battery with a pick or other pry tool you’ll be good.
Finally, you will want some kind of adhesive to put your back glass back on the phone. iFixit might have something otherwise see what you can find online.
Motorola Moto G6 Screen Replacement
Was dit antwoord nuttig?
Score 3
https://www.youtube.com/watch?reload=9&v... this film shows step by step,
Score 1
In this it shows you how. Why does my phone black out when making a call
Voeg je antwoord toe
Dem O'crat zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 17
Altijd: 9,351
