Ga door naar hoofdinhoud
Uitgekomen op 4 november 2017. Model A1865, A1901. Verkrijgbaar als GSM of CDMA / 64 of 256 GB / Zilver of Space Gray. (Uitgesproken als "iPhone 10".)
1199 Vragen Bekijk alle
iPhone X no power.
Hello everyone.
I have am iphone X qualcomm that would not power.
When i hook up only the top layer of the pcb to dcps, the top layer draws current before prompt to boot. But i tested with a DMM and found no shorts on PP_VDD_MAIN and PP_VDD_BOOST.
now i wonder what other lines could draw current before prompt to boot.
Any help is appreciated.
THANKS.
Is dit een goede vraag?
1 Opmerking
Are you sure your power squid is good?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
How much current? It’s not like there is some main switch on the logic board that cuts all the current to the components.
Take a look at the schematic and the moment a battery or a USB power source is connected, quite a few components receive VDD_MAIN. There is a line called PP1V8_ALWAYS and as the name suggests…it is always on.
So if the board is still dead, focus on all of the subsystems powered by the PMIC to see if there are any shorts or related issues. They may be the cause of your problem.
Was dit antwoord nuttig?
Score 2
Use this as a reference https://www.youtube.com/watch?v=nuZz_D1u...
Voeg je antwoord toe
Abdulmajid Mubarak zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 7
Altijd: 299
