Kernel panic and HDD format questions
I did another replacement of capacitor C9560 on a 820-2850 board (2010 MBP 15” ), and it ran fine after with a fresh install with a High Sierra HDD. I used the cap I bought from Louis Rossman’s store, the oversized unit, and also had replaced the trackpad, which had been the only error showing in ASD after the surgery.
I was ready to give it to a new owner, but upon inserting the new owner's old SSHD (which had previously been in one of those infamous 2011 MBP with a 820- 2915), the 2850 did a panic again, even with the new cap.
Are there other reasons to panic on these 2850 boards beside the cap? I’m currently running Disc Warrior on the new owner's SSHD (which had previously been in the infamous 2011 MBP with a 820- 2915), and it showed 7 out of 10 in the optimization index. Could it be that the machine did the kernel panic just because I installed his SSHD which was subjected to kernel panics in the owner previous 2915?
Another factor which MIGHT play into the crash of my freshly re-capped 2850 has come to light: The SSHD I had tried to implant into my freshly re capped machine had a " Logical Volume Group" Type, and a "Logical partition" format. Being the rookie I still am (for the time being) , I am drawing blanks as to what that means, other than that when I put my own "GUID Partition Table " formatted HDDs into the machine, it crashes no more… Can anyone shed some light please?
Is dit een goede vraag?
What did the panic report tell you? The answer is there!
door Dan
Not sure how to insert an attachment for a pdf file here : So I copy and paste the first part only to stay below the 1000 symbol limit: Panic Report
panic(cpu 3 caller 0xffffff7f841a4bc9): "GPU Panic: [<None>] 5 3 7f 0 0 0 0 3 : NVRM[0/1:0:0]: Read
Error 0x00000100: CFG 0xffffffff 0xffffffff 0xffffffff, BAR0 0xd2000000 0xffffff911ea8a000 0x0a5480a2,
D0, P2/4\n"@/Library/Caches/com.apple.xbs/Sources/AppleGraphicsControl/
AppleGraphicsControl-3.12.9.1/src/AppleMuxControl/kext/GPUPanic.cpp:127
Backtrace (CPU 3), Frame : Return Address
0xffffff910dacaee0 : 0xffffff80016dab52
0xffffff910dacaf60 : 0xffffff7f841a4bc9
0xffffff910dacb040 : 0xffffff7f85168a6a
0xffffff910dacb100 : 0xffffff7f852359e8
0xffffff910dacb140 : 0xffffff7f85235a53
0xffffff910dacb1c0 : 0xffffff7f854a9a85
0xffffff910dacb330 : 0xffffff7f85257711
door Jurgen
