Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
1041 Vragen Bekijk alle
Touch screen is acting crazy after a year
I replaced the screen on my daughter’s iPhone 6s+ (with an iFixit screen) just over a year ago. A few days ago, it started to spaz - acting like it was being touched and swiped when nothing was touching it. I removed the screen protector, took it out of its case, and even cycled the power and did hard resets. Nothing would stop the behavior.
Is it possible that the screen has gone bad (just after the warranty expired, of course)? Is it worth replacing the screen again, or is it possible that something else is wrong. I don’t know if this model is prone to “touch disease” or if some other component might be causing this problem - or is it just the screen?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
The iPhone 6S does not suffer from Touch Disease. If your screen is ghost touching, then it is most likely just a bad screen. Replacement screens for the 6S are pretty cheap nowadays and the phone still holds it’s value and is powerful enough for daily use. I would fix it (full disclosure: I own and use an iPhone 6S :-). Contact your vendor, they may be able to help you out.
Was dit antwoord nuttig?
Score 8
Its just the screen. Replace the screen and you should be fine.
Score 1
As the OP said already. You need to replace the screen again.
Voeg je antwoord toe
David zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 1,502
