Ga door naar hoofdinhoud
Reparatiehandleidingen voor persoons- en vrachtvoertuigen op 4 wielen.
11847 Vragen Bekijk alle
Temperature gauge reads hot
Hi, I have a Ford Focus 53. Have a problem with the temperature gauge reading hot when I do over 50mph or uphill, if I slow down it goes straight back to normal, it’s not actually overheating. It only does it when I have the heater fan on, which my garage says is impossible, any ideas?.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Yes, that is weird that the temperature gauge shows hot when the heater fan is on and you are going uphill or over 50mph. The heater is linked to the engine cooling system and it should transfer heat from the engine to the passenger compartment and reduce engine heat.
My guess is that it may be a faulty sensor, loose or dirty connection on the sensor or the gauge. You did not mention if your garage checked the sensors or the cooling system, try going back and have them check the cooling system and sensors/connections.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Claire zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 44
