Ga door naar hoofdinhoud
Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
104 Vragen Bekijk alle
compatible hard drive replacement
iMac EMC2210
Is there a compatible Western Digital Caviar Black hard drive replacement for a WDC WD5000AAKS-40YGA1? Mine has failed and I would like to upgrade - possibly another 500GB or even a 1TB. Help please!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
any 3.5 inch SATA harddrive should work fine. Keep in mind that some drives operate hotter then others and a hotter drive will make the HDD fan spin up more. Make sure to securely reattach the HDD thermal sensor to the new drive.
If you are looking for a definite answer with a specific model number then it would all depend on where you are going to purchase from.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Jack McClafferty zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 1,401
