Ga door naar hoofdinhoud
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
281 Vragen Bekijk alle
MacBook 12" 2015(820-00045) no display, no chime, no image
Hello, @arbaman @reecee @refectio and other experts!
Recently I received a dead MacBook 2015 12”. When I connect charger, no chime no image, no backlight.
  1. I tried measure every power line with multimeter, but I found missing voltage only on PP5V_S0SW_LCD, PP5V1_S4SW and PP1V05_S4SW lines
  2. I use my ThermoCam and compared the thermo image with good working board but images look the same. So I think there is problem only with image and backlight (maybe)
  3. I disconnect everything and connected a known good display but does not help
  4. I preventatively replaced U4700 but no change
On the internet I found, than a lot of people have same issue with this model. Is here any way how to fix?
board number is 820-00045
Is dit een goede vraag?
2 opmerkingen
Did you press the re-set button on the battery connector?
door
sure man, also tried smc reset, reconnect battery
on the board is not present
EDP_BKLT_EN
EDP_PANEL_PWR
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I haven't much experience on A1534 boards unfortunately, I have a dead board around for a few months now but haven't had the time to get deeper into it. Do you have an adapter you can try to plug into an external screen to help you point in the right direction ? The missing enable for backlight might be your issue indeed.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
sure i tried connect external display but no image :)
on the board are not present
EDP_BKLT_EN
EDP_PANEL_PWR
door
Sadly, I think your best option is to replace the logic board MacBook 12" Retina (Early 2015) Logic Board.
MacBook 12" Retina (Early 2015) Logic Board Afbeelding
Product
$249.99
Voeg je antwoord toe
Tomas zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 990
