Ga door naar hoofdinhoud
Alles wat je nodig hebt om je iPhone zelf te repareren! iFixit biedt gratis reparatiehandleidingen en demontage-informatie voor elke telefoon, alsook de beste vervangende onderdelen en handigste tools.
36471 Vragen Bekijk alle
iPhone 6S backlight intermittently out after battery replacement
I replaced the battery in my iPhone 6S.  After doing so, it turned on and appeared to work normally for about a day, after which the backlight went out and the screen went dark.  I have found that if I open it, and disconnect/reconnect the battery, the backlight will come back on for a short time (10 - 15 min), but then go back out again.   Any ideas what could cause this sort of behavior?  Thanks!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
It’s very important to always disconnect the battery before disconnecting/reconnecting the screen assembly. The issue is that the LCD connector has pins that have high voltages (i.e. the backlight is ~20V) and ground in very close proximity. When you fumble around trying to line up the connector plug to the receptacle, you can short out the voltage rail and cause damage to the components in the backlight circuit. If you’re lucky, then only a backlight filter is damaged but other times, the entire circuit could be affected. Either way, this type of repair requires micro-soldering and isn’t really a DIY repair.
To test for this, plug your device into a charger or an iTunes enabled computer. Then shine a bright flashlight on the screen. If you can see a dim image, then the backlight circuit has been damaged. If you can’t see an image at all, then it may be the LCD circuit that is damaged.
You can connect the original, cracked screen to confirm this. If the original screen has the backlight on, then the replacement screen has an issue. If the original screen also doesn't show the backlight, then the backlight circuit is blown.
If iTunes doesn’t recognized the device than the problem is more than just a screen or backlight issue.
Was dit antwoord nuttig?
Score 5
Voeg je antwoord toe
Bob zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 479
