Ga door naar hoofdinhoud
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376 Vragen Bekijk alle
shows green light but cannot power on
Sorry guys for interrupting you but I kinda have a problem with my MacBook 820-2330-A.The machine shows green light but cannot power on,however when I press the power button and then plug the charger in the machine comes on but fans run at a very high speed and there is no backlight.I’m new to this stuff and I don’t know what to do…please someone help.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
That points to an SMC circuitry failure as what you’re doing to start it is an SMC bypass. It’s a logic board issue that needs in depth probing and a component level repair, or a logic board replacement, which would be more suited from a DIY approach.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
KEN ROBERT zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 123
