Ga door naar hoofdinhoud
A1706 / EMC 3071—Released in November 2016, this 13" Macbook Pro introduces the OLED Touch Bar. Features a dual-core "Skylake" Intel Core i5 CPU and four Thunderbolt 3 ports.
239 Vragen Bekijk alle
How to remove and replace the touch bar
I have a touchbar that does not light up at all (I can still use it, change brightness of monitor, backlighting of keyboard etc.) but the touchbar itself is completely black/blank.
I have scoured the internet for days and have yet to find any sort of tutorial/video etc. that demonstrates the process of removing the touchbar and installing a new one.
There are sellers on Ebay that sell new touchbars:
https://www.ebay.com/itm/Macbook-Pro-Ret...
But without a clue as to how I would go about replacing my broken touchbar, I”m at my wits end.
Ifixit did a teardown in 2016 where they attempted to remove the touchbar, but they were unsuccessful (that’s putting it mildly). But I think in the proceeding 2 years someone has figured out how to fix this part.
https://www.youtube.com/watch?time_conti...
Anyone that could point me in the right direction would be immensely appreciated and I’d be happy to buy you a beer ala paypal for your kind contribution.
Thanks!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
I’ve replaced two! While its not an easy job it can be done.
The IFIXIT teardown crew was on the right path, you can’t take it off without killing it! After taking the TouchID button off allows you access to the edge to lift the bar from. You’ll need to protect the display and the rest of the keyboard from damage both from heat and solvent. Once you’ve taped off the area with wide Polyimide Tape and aluminum foil use a focused heat gun to heat up the TouchBar so the adhesive is softened up using a small spatula lift the bar off as best as you can without damaging the uppercase. Once the majority of the bar is removed you’ll need to use Goof Off to clean off the last of the adhesive and any pieces that are still present.
But before you go this far I would carefully disconnect the battery and then hookup the new TouchBar to make sure the issue is the bar and not the logic board logic.
Polyimide Tape Afbeelding
Product
Polyimide Tape
$9.99
Was dit antwoord nuttig?
Voeg je antwoord toe
icymac zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 30
Altijd: 2,132
