Ga door naar hoofdinhoud
Part of the Acer Gemstone series, the Acer Aspire 7736Z-4809 offers a larger display than most laptops. Repair of this device is similar to other models in the 7736 series.
4 Vragen Bekijk alle
Why does my pc take a long time to turn all the way on.
When my Pc dies or automaticlly turns off I try turning it on , when it does it shows the text Acer and a blue loading bar. After that the screen goes to a dark blue screen , then the laptop it self starts making a sound as if it breathing.Then I’ll wait about 2-5 minutes to enter my home screen.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Sounds like your hard drive is slowly dying.
To test it, after booting to the home screen, click on “This PC” or “My Computer”.
When (C:) appears right click on it, click on “Properties” when menu pops up click on it and select “Tools” (at top left between “General” and “Hardware”) you will see “Error checking” and click on “Check” and Scan drive.
After the scan finishes it will tell you if there are any errors on the drive.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Emani Coleman zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 96
