Ga door naar hoofdinhoud
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Vragen Bekijk alle
Switch Unibody From MacBook Pro to MacBook
I have a Mac Book Pro with a Broken Screen and keypad. I also have a Mac book that everything is fine on. Can I switch all the internal parts on the Mac Book Pro and make them work in the Mac Book A1278 Unibody?
Is dit een goede vraag?
1 Opmerking
Mac Book Pro has a SD card port. Mac book does not
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Are they both A1278 model MacBooks? If yes the keyboard is switchable. The screen however will are not compatible if they are too far apart from the years. You’ll be able to tell once you open the bottom of both of them and look at the display connector. Both ones should have the same connector and latch on the cable.
Was dit antwoord nuttig?
Score 3
Do still need help with your book?
Voeg je antwoord toe
Bruce Spafford zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 58
