Ga door naar hoofdinhoud
Released in 2017, the JBL E45BT are wireless on-ear headphones with Bluetooth 4.0 and 40 mm drivers, rated for 16 hours of battery life.
79 Vragen Bekijk alle
replacement parts for broken flexible joint?
Unfortunetly, the flexible joint between the bracket and the earpads is broken. I could fix it with a tape, but this is a disapointing workaround. Is it possible to get replacement parts for it?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Hey Martin,
Unfortunately I cannot seem to find any replacement parts, on iFixit or elsewhere. I might suggest either wrapping the joint tightly with electrical tape and some masking tape or, for a cleaner fix, you might be able to get some heat shrink tape/tubing and tighten it up by applying heat from a hairdryer.
Otherwise, take my advice with headphones:
Whenever you buy any electronic, like headphones, buy them from Amazon and purchase the 3-year warranty (about $20). In the event they break, which headphones usually do, you can just send them to the warranty company and they will either send you a brand new pair or (in most cases) they will give you an amazon gift card with the value of the headphones when you purchased them.
Example: I bought Beats Solo HDs for about $200 when they were new. They stopped playing out of the left ear. I sent them back and got a $200 gift card. I then applied that to a purchase of the Beats Solo 2s.
The Solo 2s ALSO stopped playing out of the left ear, but I love the beats, so they gave me another gift card, which I used to buy a pair of the wireless Solo 3s. Each time I bought my new pair, I just got a new warranty plan to go with them.
Although my friends hate on me for “scamming” the warranty companies, I’m not going to pay $200 for headphones that will break after a year. I’d rather pay $20 extra for a protection plan which will allow me to upgrade to the newest product.
Let me know if this helps!
- Alex
Was dit antwoord nuttig?
Score 2
This is hinge for 650bt incase its similar.
You can download this 3d hinge for 3d printer, my pin came out so used metal pin and bent edges till I find other method.
https://www.thingiverse.com/thing:533616...
Original post link:
https://www.reddit.com/r/JBL/comments/ox...
broken pin replaced with a piece of guitar string works a treat no gluing or tape ; just long nose pliers and some bending , i used an A string ~3mm+ spare for bending ridges hold it in place
Voeg je antwoord toe
Martin P. zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 41
Afgelopen 30 dagen: 117
Altijd: 2,560
