Ga door naar hoofdinhoud
Released September 22, 2017. Model A1864, A1897. Available as GSM or CDMA, 64 or 256 GB Storage Options, and the color options are gold, silver, and space gray.
Home button stopped working
I replaced a lot of things on an 8+ and after putting everything back the home button stopped working. The screen wasn’t replaced but the homebutton was the only thing that stopped working. Could it just be the ribbon cable that connects to the logic board and if i wan’t to keep touch id would it still work?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Chances are the cable for 3d touch and home button connection got damaged.
As long as the home button wasn't touched replacing the screen will fix that problem.
If you haven't already try reseating the screen connections while battery is unplugged.
Was dit antwoord nuttig?
Score 1
Sad thing is: iPhone 7 and 8 don’t have a real home button. The button that came with the phone is the only button that will work. You can’t replace the button, or else it won’t work in any way.
Score 1
Voeg je antwoord toe
Axel Salas zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 122
